removing wheels
Old May 14, 2009 | 09:10 PM
drifts500's Avatar
removing wheels
I do not have impact gun and I just have OEM wrench for wheel. Do I need to use jack to get off the nuts and to put them back? I am afraid while im driving, the wheels might fall off...;;; help me how to remove wheels..
Old May 14, 2009 | 09:34 PM
TroysG's Avatar
wow... you should not be allowed to drive.
1. loosen nuts WITH WRENCH - provided your taking off OEM wheels with OEM nuts
2. jack up whichever corner you're taking the wheel off with OEM JACK
3. finish taking off wheel (loosening the nuts to point they fall out
4. do whatever you're doing.
5. do step 3 in reverse
6. do step 2 in reverse
7. do step 1 in reverse
8. after driving 50-100 miles RE TIGHTEN WHEEL NUTS
Old May 14, 2009 | 09:49 PM
drifts500's Avatar
I mean..the nuts are like stucked..I cannot even remove them with OEM wrench
Old May 14, 2009 | 09:50 PM
bigc's Avatar
Wings Nation
get yourself a proper breaker bar & torque wrench and you'll be all set
Old May 15, 2009 | 12:52 AM
Shrummi's Avatar
the lug nuts wouldnt come off on mine either.....buy a nice long breaker bar and your good to go. mines 25" and a girl could take off the lugs with one hand with it.
Old May 15, 2009 | 01:12 AM
drifts500's Avatar
K thanks ^ I will try with a breaker bar
Old May 15, 2009 | 01:20 AM
Shrummi's Avatar
i don;t know if you have these stores up there but Harbor freight tools is where i got mine. they have every tool imaginable....
Old May 15, 2009 | 01:42 AM
drifts500's Avatar
I even put my weight on the OEM wrench and could not get them...I really hope that I could take them easily with the breaker bar...
Old May 15, 2009 | 01:51 AM
Shrummi's Avatar
breaker bar makes it easy especially if you get a good sized one.
Old May 15, 2009 | 12:25 PM
tonke73's Avatar
Do you have a 1/2 inch diameter pipe that is 18 inches or greater in length? If yes, slide the pipe over the OEM wrench and use the pipe as a breaker bar.
Old May 16, 2009 | 04:04 PM
drifts500's Avatar
No..that is why im buying a 24inch breaker bar..I hope this will easily take off the nuts..
with the OEM wrench, I even put my weight on it.
skippyG
Jan 25, 2016 01:18 PM
Ray Feta
Aug 20, 2015 08:46 PM
TL2G35x
Aug 12, 2015 10:30 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
