Someone please help! With my g
Old Jun 3, 2009 | 10:07 PM
michael200's Avatar
My 2005 G35 Coupe Runs out of gas before on empty and the low fuel light does not turn on, has anyone ever had this problem before?...what should i do?
Old Jun 3, 2009 | 10:14 PM
PAIXAO's Avatar
Are you still under warranty? If so I would take it to the dealership and have it fixed under warranty. Otherwise, take it somewhere and have them look at it. Nissan's labor rate is cheaper than Infiniti's
Old Jun 4, 2009 | 08:41 AM
OBG3506's Avatar
Sounds like the ascending unit in the tank is stuck or bad!
Old Jun 4, 2009 | 10:41 AM
pwebb's Avatar
ascending unit?
yeah... you most likely need a fuel pump (sending unit). instrument cluster is also a possibility, but far less common.
Old Jun 4, 2009 | 11:06 AM
G35fromPA's Avatar
Fuel tank sending unit known to be an issue in earlier coupes. Had mine replaced under warranty.
File Type: pdf
