I just installed headers in my 06 G35 and I must say that it was not an easy task. Upon completion there were no leaks and everything seemed to be working well. The only problem I had was the low air pressure indicator light which came on and in spite of putting enough air in the tires, the indicator light has remained on. I have also attempted to clear the code by disconnecting the neg terminal of the battery. Any ideas as to what could be causing this problem..
Quote:
What monitor you are referring to.. ThanksOriginally Posted by pwebb
the monitor could have gone bad. I see it a lot. it will be covered under warranty.
