Cold air from AC only works at 60 Degrees
Old Jul 28, 2009 | 02:40 AM
nycityinsomniac's Avatar
When i go up to 61 Degrees very hot heat comes out.
It seems 60 is the coldest and everything above it is as hot as it can be.
I just installed a new JDM AC controller with the double din kit.
Anyone know whats going on?
Also i have an airbag light on now
Old Jul 28, 2009 | 04:39 AM
G SEDAN's Avatar
all you have to do, is open your the dash cover under your steering wheel, toward the right side of the panel (right above where your right knee would be) you should find a large black tube. The tue attaches to a vent that has a grill coming out of the panel almost. Right above that tube, you will see a lil plug. That plug has to be attached to a white plug (one which you forgot to plug in). Find that loose plug buried somewhere inside the jungle of wires in there. You may even need to remove the panel beside your jdm finisher to find that plug.
Once you find that plug, just plug it right in and your AC will be back to normal. You simply forgot to plug back the ac temperature sensor, it's a fairly common mistake.
as far as the airbag.........did you mess with any of the airbag sensors at all? You shouldn't have needed to...........
champppy
Mar 31, 2020 12:25 PM
MR M37s
Oct 30, 2015 08:32 AM
underworld
Aug 6, 2015 01:36 PM
paniaguag35
Jul 29, 2015 12:05 PM
justgotg35
Jul 19, 2015 12:33 PM
