Regrease n Clean Axle Twice n Click comes right back
Old Sep 21, 2009 | 02:44 AM
DDD*G35's Avatar
Had the rear axle clean n regreased twice at the shop it goes away and then within a day it comes right back. I noticed with heavier weight the clicking gets louder . Any one help ?
Old Sep 21, 2009 | 11:49 PM
4DGS's Avatar
It needs to be replaced. Not cleaned and greased.
Old Sep 21, 2009 | 11:56 PM
Glex25's Avatar
Administrator
Did you rotate the axle 180deg like the TSB says
Old Sep 22, 2009 | 12:30 AM
DDD*G35's Avatar
Yes it was rotated. I have to replace it ? Did you have the same problem as me ?
Old Sep 22, 2009 | 12:48 AM
DDD*G35's Avatar
Axle
Which part do I need to replace specificly can to refer to a website ?
4DGS's Avatar
No, but that is that is what pretty much everyone else has done. I'm pretty sure infiniti does that when you bring it in for warranty.
Old Sep 22, 2009 | 12:52 AM
4DGS's Avatar
Hold on, I'll try and dig up a thread.
Old Sep 22, 2009 | 12:54 AM
4DGS's Avatar
Maybe I'm smoking crack maybe it doesn't need to be replaced. I'm still looking though.
Did you follow this method?
https://g35driver.com/forums/engine-...xle-fixed.html
Old Sep 22, 2009 | 12:59 AM
Glex25's Avatar
Administrator
The only thing that was replaced on that TSB was the bolts that hold the driveshaft to the axle stubs on the differential
Old Sep 22, 2009 | 01:11 AM
DDD*G35's Avatar
Yeah the shop did i dnt have warranty with infiniti no bolts and nuts were replaced though.
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
wuppiedog
Aug 7, 2015 11:16 AM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
johnjohn077
Brakes
Aug 4, 2015 01:37 AM
apintojr
Jul 23, 2015 10:52 AM
