Help!?!?!?!?!?
Old Oct 20, 2009 | 12:35 PM
RomoG35's Avatar
Help!?!?!?!?!?
Hello
Just a 05 g35 and i cant rev past 3500 rmp in any of the gears. I was wondering if any one know whats going on, and how to fix the problem.
Thank you
Old Oct 20, 2009 | 12:43 PM
Deezflip's Avatar
you should be getting a CEL light
pull the code(s) first...
timing is real critical so use a watch or a timer with a second hand to help
1. turn ignition on
2. count 3 seconds
3. step on the gas pedal 5 times in 5 seconds
4. wait 7 seconds
5. step on the gas pedal till the CEL starts blinking.
From there the first long blink is the indicator blink followed by a series of short blinks with short pauses in the middle.
ie. 1 long blink - pause - 6 short blinks - 6 short blinks.
that indicate you have a P0166 code. If you have multiple codes -
ie. 1 long blink - pause - 6 short blinks - 6 short blinks - pause - 1 long blink -pause 7 short blinks - pause - 2 short blinks.
that would indicate you have 2 codes, P0166 and P0172.
Then refer to http://www.troublecodes.net/OBD2/Pcodes.shtml
Old Oct 20, 2009 | 11:33 PM
RomoG35's Avatar
i got two codes P0113 and P0102 which are both related with the mass air flow sensor. Im wondering if i change the mass air flow sensor would it fix the problem?????
Old Oct 20, 2009 | 11:39 PM
Deezflip's Avatar
it just might need some cleaning. Do you have an aftermarket intake? Or maybe did some re-oiling or cleaning of the filter? It's possible that some of those liquids leaked onto the MAF sensor.
Disconnect the battery, buy some non-residue contact electronic cleaner from radioshack and just spray it and let it dry....don't brush or scrub it, that would instantly damage it. Then reconnect the battery after your done.
Old Oct 20, 2009 | 11:52 PM
RomoG35's Avatar
i have a after market intake on it clean it and the mass air flow sensor and still nothing happened. i got a obd2 reader and erased the codes but the car still doesn't rev past 3500 rpm!
