grounding trouble,please help
Old Feb 18, 2010 | 04:26 PM
IrockAG35's Avatar
Ohio G Club moderator
i recently pulled my motor a few weeks ago to do a bit of work. i re-installed motor last week,connected all my plugs back the way they were(labeled) im comming accross a problem with my alternator ground wires(friend removed them w/o labeling) when i try and connect or jump the batt.,im getting a NASTY spark,which is a tell tale sign of improper grounding ,jumpers also get really hot ...question is about ground wires for alt. where do the 2 grounding points bolt up?
wire is as described- comes from main ground,has an 'eye" that connects to alternator then wire continues to an "L" shaped end(cant figure out where this wire goes) both have rubber gromets..any suggestions? ive tried grounding to chassis and block,both failed.
thanks,mike
Old Feb 19, 2010 | 12:30 PM
IrockAG35's Avatar
bump...anyone have a written diy with pics of alternator install?
Old Feb 19, 2010 | 11:41 PM
IrockAG35's Avatar
problem solved,mods please close thread
Old Jan 10, 2011 | 12:12 PM
dj codeman's Avatar
what was the problem and fix>?
Marlin84
Apr 1, 2020 12:52 PM
prinny
Nov 22, 2015 11:07 PM
dseet
Oct 11, 2015 12:40 AM
