Driver window switch pin configuration
Old Mar 17, 2010 | 08:48 AM
Phoenixfreeway's Avatar
Got a problem with an 03 or 04 g35 coupe. Owner was trying to disassemble the driver door without unpluging the window switch, and the switch plug came apart. They called me to put it back together, but I could only get access to an 07 g35 coupe window switch plug. And now the passenger window works correctly, door locks work correctly, driver window goes up and down with auto down. But auto up does not work and the opening and closing of the driver door only makes the window crack down but not back up. The switch had to be replaced due to the owner shorting the circuit board. I was wondering if any one who had a 03 or 04 g35 coupe could take a picture of both sides of there window plug so that I could be sure that I got the wires put back in the right pins. Thanks in advance!!!
Old Mar 18, 2010 | 06:10 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Here's something that may help out:
http://www.psedog.com/cars/fsm/g35/coupe/2003/idx.pdf
Not sure which section the windows are in, but that's the index, should get you to the wiring diagram/pinout that you're needing.
will091195
Jul 27, 2015 09:19 PM
Kal Hamm
Jul 24, 2015 08:55 AM
apintojr
Jul 23, 2015 10:52 AM
vstypicals
Jul 20, 2015 10:55 PM
