how to program garage door?
Old Apr 19, 2010 | 03:31 PM
rt10g35supra's Avatar
how do i program my garage door to my 04 coupe.
Old Apr 19, 2010 | 03:35 PM
GAU-8's Avatar
Need more info. How old is your garage door opener? If it's an older one with the program code switches, you should simply be able to hold the remote button down while holding down the button in your car for several seconds and you're done. If it's one with rolling code technology it's more complicated. You'll need to hold the reset button on the garage door opener while someone holds down the button on the remote and the button in your car. That needs to be done 2 or 3 times before it grabs the code.
Old Apr 19, 2010 | 08:36 PM
thanks for all your help. ill try it later tonight when i get home. ill let u know how it went
TNRocker
Sep 21, 2015 08:36 AM
Detailed Image
Sep 18, 2015 03:43 PM
Detailed Image
Sep 17, 2015 07:38 AM
