Air Conditioner Problem
Old May 18, 2010 | 09:55 AM
DG_coupe's Avatar
Hey guys, just acouple weeks ago my AC stopped working. I thought I had low refrigerant so I went ahead and bought a can of R-134a. When I tried to put some in the gauge showed red stating there was too much pressure in it.
Does that mean I should release some pressure? Also how would I go about doing that? I don't think it's my compressor because my fan spins and I also hear a clicking sound when I turn on the AC.
Also I tried searching but found no answer. I also checked if my Z tube was rubbing on the lines to make them leak but saw nothing.
thanks in advance.
Old Jul 23, 2010 | 10:51 PM
03_G_'s Avatar
bump
I am having same problem just started a few days ago. Did you get it fixed?
Old Jul 26, 2010 | 05:57 PM
GrocryGettr's Avatar
A/C systems are very sensitive to pressure fluctuations. You CAN'T simply just add more coolant and fix the problem. You need to take it somewhere and make sure that one, the a/c compressor is working and two, have the system evacuated and a vacuum pulled before any new coolant can be added.
Old Aug 1, 2010 | 11:28 PM
DG_coupe's Avatar
I should update this. So I found out my compressor was bad even though it was turning on. I changed it and it works fine.
Old Aug 9, 2010 | 06:39 PM
Sanclementeg35's Avatar
i have the same problem i put with r135 can with gauge on it and it said i had over 100 psi in my system! how did u know it was the compressor and would that be covered under warrnety ??
champppy
Mar 31, 2020 12:25 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
Jiggerjuice
Oct 5, 2015 02:33 PM
derres
Aug 28, 2015 03:27 PM
G35CO
Aug 25, 2015 02:00 PM
