HELP PLEASE, a/c blows hot air , radio works fine????
Jul 14, 2010 | 01:32 PM
So....
my a/c blows hot air not matter what setting I put it on. It was working when I got the car back in feb but really havent used it till now, radio works fine too no pproblems at all. After doing a search I checked the lines and I have no leaks (intake) and the only (other problems) that I have in the car is that the engine bay fan (nearest to the ac line) dosen't turn on at all and I have the ABS, SLIP, and VDC light on. Brackes are fine, pads are fine, and fliud is fine,rotors are old though. Took it to tire plus and after them having it for 2 hours, they couldn't find the problem either. System is good, no recharge needed. Nearest dearer is not close at all, any ideas
Thanks
Reply 0
Jul 16, 2010 | 05:35 PM
I would guess your a/c control unit is bad. We had a customer with similar problems and that corrected it.
BTW, make sure your a/c is charged because it will not turn on if pressure is too low.
Reply 0
