US 06 coupe headlight
Hi guys, just brought 06 coupe, its a US car. why is the headlight on all the time even when i turn off position? Is Canadian coupe the same?
also....its come with tires size front and back is the same 245/35/19 and pretty noisy during low speed and braking, is it the tire itself or the tire size?. will it cost any problem later?
thanks for all the feedback....
hmm.. headlights SHOULD turn off in off position. Stock tires with 19's are 225/40/19 and 245/40/19 IIRC... Noisy.? Low pro tires tend to be somewhat noisy. If they are low on tread then they will definitely be louder... your tire size shoudn't b too much of a problem but i believe the front and rears on a coupe are meant to be a staggard size..
thank you.....alfhasg35. yes i should be...but mine not...is it a glitch?
anyone have 06 coupe that he can tell me its normal for the headlight turn on every time i started the car. Cuz i know Canadian g35 have daylight, but not headlight on.
please ....
please ....
bTanz
Oct 15, 2015 02:31 PM
