Hella triple air horn install help needed g35 sedan
Old Oct 22, 2010 | 12:28 PM
Nomad397's Avatar
i am making a custom mounting bracket for the kit and installing on the drivers side fender well of my 03 sedan. what i needed to know was where the horn wires are located in the engine bay so i could tap them directly in there, also the colors of the wires would be helpful.
Old Oct 22, 2010 | 01:10 PM
Nomad397's Avatar
also does anyone know where the horn fuse is ? i need to replace it with a 20 or 25amp fuse because of the addition of the air horns
Old Oct 22, 2010 | 01:25 PM
kennymo's Avatar
wire is in the loom hat runs over the fender on the drivers side in the engine bay. dont know the colors off the top of my head. just look at the plug for them and pull the coating back a little bit and look at the colors. the fuse i believe is in the cab in the footwell on the drivers side
Jusseth
Sep 13, 2020 12:25 PM
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
vstypicals
Jul 20, 2015 10:55 PM
justgotg35
Jul 19, 2015 12:33 PM
ZacDesu
Jul 14, 2015 11:13 PM
