2004 g35 coupe 6mt gear oil leaks, need suggestions!!!
Old Feb 5, 2011 | 06:42 PM
xsangg's Avatar
my car is 2004 g35 coupe 6mt
I have replaced my clutch on april of 2010 and the gear oil started to leak from 3-4months after i installed new clutch. i believe that its leaking from the transfer case or from the seal that connects drive shaft to the transfer case i am not 100% sure. whenever i drive around about 15-20min i smell something like rubber burning.. and i looked under, the gear oil was spilled on my Y pipe and was burning from the heat.
what could i do myself to check where it is leaking from? any suggestions with a procedure? without taking it to the shop.
i refilled the gear oil about 4months ago and it is still leaking but not that much.
help me out guys, thanks!!
Old Feb 18, 2011 | 01:59 AM
xsangg's Avatar
bump, gear oil still leakin
Old Feb 18, 2011 | 02:15 AM
hurleyguys's Avatar
bump but damm good luck.
Old Feb 18, 2011 | 09:27 PM
GrocryGettr's Avatar
You need a new seal and/or drive shaft. Remove your drive shaft and replace the seal checking that the imput shaft is not scored. If so, take some emory cloth and smooth it out and retry.
Old Feb 24, 2011 | 01:27 AM
xsangg's Avatar
thank you, i will try that when i get chance!
NemesisGee
Aug 11, 2015 07:10 PM
brycealbr
Aug 11, 2015 11:47 AM
nervseele
Jul 17, 2015 11:21 PM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
