Help!!
Help!!
Okay so Installed a sub and an amp on my 06 g coupe using one of the DIY on the site. I disconnected the negative terminal and hooked everything up. When i reconnected the battery terminal, the VDC OFF, SLIP and SERVICE ENGINE SOON lights were on. When i went to start the car, it took a while to start (too many cranks, make sense?). My mechanic shop took a look at the codes and said that it was the cam shaft sensors that were bad. They replaced those, and still the same problem. Anyone know why this is?
this happened to me. i think it was not the radio at all but actually a blown cap somewhere. the guy explained that i reved the engine red line too many times which i didnt believe until i realized that the previous owner drag raced and drifted in it. il look for exactly what he replaced was
