No Power to A/C Compressor
Old Jun 23, 2011 | 08:55 PM
Warthog52's Avatar
Exclamation No Power to A/C Compressor
Hi Everyone i'm new to the forum. I have an a/c problem...no power getting to compressor. The compressor works and the system is fully charged (jumped it to check) and working. My mechanic is lost on this...He says he only found one fuse for the a/c near the battery. Are there some relays that we might be missing? Would appreciate any help...I used to do my own work but am going thru health issues at the moment that prevent me from working on the car. I live in Austin TX, if some one could make a refferral of a "Wrench" they have been happy with that would be really cool. The radio , c/d player and all steering wheel switches work fine, as well as the ventilation system. I'm just curious where the originating source of power is for the compressor. Or has anyone just put a switch in place to turn the compressor off and on?
2004 G-35 Mt6 Sedan
Lost in the Woods!
Old Jun 14, 2012 | 12:24 PM
Lucky74's Avatar
I am having the same problem & by the date you posted & the lack of answers I am guessing I will not find out the answer here, just people giving worthless answers like "does it have freon in it" & "where did you get the compressor from, they are rare" Really??? I will post when I figure it out, I WILL figure it out!
Old Jun 15, 2012 | 02:55 PM
Lucky74's Avatar
Mine was the pressure switch wires on the condenser on the passenger side, the wires had worn thin, wiggled them a little & compressor came on. Hope this helps!
Old Jun 22, 2012 | 03:18 AM
SUMATIC's Avatar
Where did you jump it to make the compressor come on?
Old Jun 23, 2012 | 12:23 AM
Lucky74's Avatar
I just put power from the battery to the coil wire (it is the wire that goes behind the compressor pulley) while the car was running to see if it would kick on.
Old Jun 24, 2012 | 06:30 AM
SUMATIC's Avatar
Does the relay work? Check the constant power to your relay and signal power to relay. If theres power to your relay, jump the relay pins (power to load side) if the compressor clutch egages, remove the jumper and check the ground pin of the relay. If no ground then fix the ground side if there is ground try replacing the relay.
Old Nov 13, 2012 | 12:29 PM
importroller's Avatar
I'm in this same boat. I jumped my compressor, and it cycled the refridgerant through that I put in with the Dye. I can't locate a leak anywhere, and I can't figure out why the compressor isn't kicking in on it's own. Does anyone know what controls the compressor? Is there a sensor or switch inline that may go bad that requires servicing that may control the compressor?
Old Nov 13, 2012 | 08:39 PM
Lucky74's Avatar
On mine it was my pressure switch, it is located on the passenger side on top of the ac condenser, mine would actually kick on & off when I would wiggle the wires to the plug
Old Nov 14, 2012 | 01:19 PM
i can't find a pressure switch at the parts store. I'm guessing its a dealer part. Closest thing I found was a coolant temp sensor which looks a lot like the pressure sensor
Old Nov 15, 2012 | 12:01 PM
Lucky74's Avatar
I got mine off ebay, part # 92136-1FAOA it is a Nissan part
Old Nov 16, 2012 | 01:51 PM
I'll search the part number. When i originally checked ebay, i couldn't find one.
edit: just tried the part number, no luck
Old Nov 16, 2012 | 03:24 PM
ok, new search on ebay just for Nissan AC Sensor did pull up some. But i think I may have found one locally for $30 at rising sun autoparts.
Old Nov 19, 2012 | 01:25 AM
This sucks. Replaced the sensor, immediately the fans kicked in, recharged the system by jumping the compressor to get things cycled through, cold air slowly started blowing. But even I reconnected the wire from the car back to the compressor, it wouldn't turn on. Any ideas of what else may control the compressor turning on?
Old Aug 16, 2013 | 06:40 PM
NewtotheGs's Avatar
did any figure this out was a relay ? mine had same problem , mechanic the wires had no power from the plug to the compressor ... not trying to thread jack lol
Old Aug 16, 2013 | 06:42 PM
NewtotheGs's Avatar
god i reaslly need to re read when i type lol "Did anyone figure this out , was it a relay ? ,mine has the same problem , mechanic said it has no power from plug to compressor.
