driver window works in reverse( I have not drank too much)
Old Jul 24, 2012 | 08:28 PM
ketch37's Avatar
So you know when you open the door the window drops down a little and then goes back up. Welll mine goes down and keeps going down... If i repeatlly open and close door the window keeps going down about 2" a whack. has anyone ever had this happen?? We just bought the car and nothing about the history of it. Thank you
Old Jul 25, 2012 | 11:31 AM
Mr. Brett's Avatar
Mine does it. I think it has to do with the motor. Try resetting it, and see if that helps. There's a DIY on the reset around here somewhere.
Old Jul 25, 2012 | 01:16 PM
Footballmania32's Avatar
The motor needs a reset. I'd find the thread for you but I'm posting from my phone. Just search DIY window motor reset, and follow the instructions. It's super easy and requires pretty much just a long Phillips screw driver at the least, or a 10mm socket w/ extension.
Old Jul 29, 2012 | 07:54 PM
ketch37's Avatar
Hey thank you very much for the info. I finally had a chance to follow what you said but unfortunetly it did not solve the problem nor change it. I followed directions to a T multiple times but no luck. One thing I did notice was that the auto function feature does not work so could that be the problem?? is the reset button on the motor broke? does it need a motor? The damn thing works fine other wise. Any other thoughts would be greatly appreciated. Awesome site!!!!!!!
mike730
Jan 12, 2018 04:25 PM
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
attarday
Jul 15, 2015 04:03 PM
