basic mod order 03 coupe
Old Aug 13, 2012 | 09:54 PM
poisonouschimp's Avatar
I plan to eventually tt my 03 coupe and am looking to get it to the ~500hp range. I started with air intake, then got a header back exhaust with test pipes. With the test pipes on I lost a sizable amount of power due to lack of back pressure. With the stock cats back on the power is back. My question is what is a good order to follow so I don't run into the same issue?
I have upgraded cams and pelldulum spacer waiting to be installed.
Old Aug 13, 2012 | 10:18 PM
OldManRivers's Avatar
if your going FI save your money the work from there...
Old Aug 13, 2012 | 11:37 PM
jninja26's Avatar
You realize that the 500whp club is generally found around $20,000+ right? Could easily be more. And not likely, but possibly less if you find great deals and do a lot of your own work.
R350k5
Oct 1, 2015 08:41 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
sick_sixspeed
Jul 21, 2015 01:59 PM
Ninjay16
Jul 20, 2015 01:21 AM
