Sub Frame Question
Old Oct 14, 2012 | 07:19 AM
DRG35R's Avatar
20 Year Member
G35 Coupe "Sport Package"
Sub Frame Question
2005 G Coupe
installed a set of jack pads into the sub frame of my 2003 VW Passat yesterday and was wondering if the G has the ability to accept jack pads in the sub frame.
just wanted to check if anyone knew before I have to pull the car out of the garage and jack it up to look underneath.
my VW has holes in the sub frame that were covered with plugs. just removed these with a screwdriver and installed the jack pads that seat into the sub frame with the speed jack.
my friend who is a GM shop foreman said he had never seen anything like these before. makes jacking the car up even easier now.
would love for the same kit to fit the G if it has the sub frame holes for mounting.
anyone know? thanks in advance.
Old Oct 15, 2012 | 06:21 PM
rsingerG35's Avatar
The G's do have jack points. I believe they're outlined in the owner's manual.
Old Oct 16, 2012 | 05:25 AM
DRG35R's Avatar
20 Year Member
yes, thank you I am aware of those, but that is not my question.
Old Oct 16, 2012 | 01:47 PM
rsingerG35's Avatar
IMO anywhere on the subframe should be fine. Just not on any suspension areas.
migurus
Sep 5, 2015 09:39 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
