Get your fuel door lock working for less than $1 and 10 minutes
Old Feb 20, 2013 | 09:30 PM
chadster2049's Avatar
I pulled up to the gas station and couldn't fill up due to my fuel door not unlocking. I figured out a way to repair it quickly, easily and cheaply. I didn't easily find another post like this so I thought I would post it and maybe help someone out.
My door would lock on its own but I had to manually unlock it. If your motor is dead in the lock then this won't help you out.
Parts needed:
Spring
Washer
small zip tie
I purchased the softest spring I could find at ACE hardwary $.75 and the smallest fender washer they had for $.11
I drilled out the fender washer so it would fit over the shaft on the backside of the latch.
Cut spring so that it is just longer than the shaft, put on the washer and zip the zip tie to hold it all together.
Test it out and enjoy.
When purchasing a spring you don't one that is too strong, try to get the softest one you can find.
Attached Thumbnails Get your fuel door lock working for less than alt= and 10 minutes-image.jpg   Get your fuel door lock working for less than alt= and 10 minutes-image-1-.jpg
Old Mar 8, 2013 | 10:03 AM
zzoeller's Avatar
good deal thanks for this .. one of the best ive read, im tired of pulling my trunk liner out. especially with my sub in the trunk lol
Old May 3, 2013 | 09:14 PM
G_DiRTY5's Avatar
My fuel door has never locked since I got the car. I'm not too sure whats wrong with it and it doesn't bother me but there is a lock on it for a reason. I don't know if this $1 fix would help me though because my problem is the door doesn't lock at all.
But hey at least the door unlocks.
mike730
Jan 12, 2018 04:25 PM
xluke
Jul 30, 2016 01:48 PM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
