code p2135? car went into safe mode 3 times this month..
Old Apr 3, 2013 | 11:12 AM
g35jenna's Avatar
Hi, Im in orlando ,just wondering if anyone has had similar problem with their 2004 g coupe?
Old Apr 3, 2013 | 07:09 PM
UCIMAplaya2's Avatar
Its a pretty common problem really. It relates to a throttle position problem. There are two possible causes.
1. The throttle position feedback sensor in the throttle body has gone bad. It is not replaceable/serviceable so you have to replace the whole throttle body. This is the most likely cause.
2. The other possibility is a bad gas/throttle pedal. Its electronic (throttle by wire) and they do fail as well. Though you sometimes get a different code with this if I am not mistaken.
Try resetting the code and entire ecu and it may go away for a while. unlikely if it has happened 3 times.
There should be a bunch of threads on this site about that code if you do a quick search
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
Joshua615
Aug 31, 2015 12:29 AM
joel extreme
SOCAL Meetings & Events
Jul 23, 2015 04:13 AM
Jadenkid22
Jul 14, 2015 12:33 AM
