Driver side window issue
Old Jun 5, 2013 | 09:44 AM
digimurda's Avatar
hi all,
i have a 03' g35 coupe..
the driver side window stopped working so i figured it was just the motor since its a common issue,
i took the motor off, but then i got an electric power tester and checked the harness that goes to the motor and got no power reading while holding the window button up or down, can the issue be the switch?
i aslo ran some low current directly to the motor and it moves,
someone please help,
fuse? window switch? motor?
digimurda's Avatar
checked the fuses and all is fine,
Just noticed that when the motor is plugged in
It does not work or even make a noise when I press
In the window button up or down, but when I open the door
It turns, but only when I open, it doesn't do anything when
Closing.
Old Jun 5, 2013 | 11:09 PM
bakwoods's Avatar
Closing.
Pinched wire in the boot. You'll have to take the panel off and pull the harness to see where it is. Have you tried doing a reset? Check it out and see if resetting the window will work. I suspect it's electrical and not mechanical.
mbe093
Lights
Oct 2, 2016 11:09 PM
Ludz
Lights
Mar 28, 2016 02:06 AM
R350k5
Oct 1, 2015 08:41 PM
apintojr
Jul 23, 2015 10:52 AM
vstypicals
Jul 20, 2015 10:55 PM
