Is this normal fuel pressure with walbro?
Old Oct 6, 2013 | 06:33 PM
joeb1983's Avatar
G35
Fuel pressure too high?
A buddy said my fuel pressure was high...(66-68psi looks like) I have a Walbro GSS342 pump purchased from Injected Performance, ID725's from T1 and a fuel pressure gauge adapter w/ direct reading gauge. Stock fuel system other than that... What you think? Anything to worry about? This is @ idle...
Old Oct 6, 2013 | 08:47 PM
joeb1983's Avatar
G35
Anyone?
Old Oct 7, 2013 | 09:26 AM
joeb1983's Avatar
G35
morning bump...
Old Oct 7, 2013 | 10:57 AM
joeb1983's Avatar
G35
Is there another mod that needs to be done other than trimming the tabs on the pump inself? I followed a thread on the install of the pump to the "T", but I read elsewhere today about a fuel pump hanger mod to achieve proper flow, but searchng for that mod it brings up return sytems. Heres what Injected Performance states on there listing for the pump;
"Your factory fuel pump hangar will require minor modification to achieve the correct fuel flow"
Old Oct 7, 2013 | 12:44 PM
joeb1983's Avatar
G35
Found this, so it looks like I may have missed a couple things...
http://blog.cj-motorsports.com/2011/...tallation.aspx
Old Oct 7, 2013 | 08:34 PM
N8Deezy's Avatar
It should be 40psi with the vacuum line hooked up and 50psi without it.
Old Oct 12, 2013 | 03:14 PM
joeb1983's Avatar
G35
Performed the swirl jet and regulator mods per CJ Motorsports instructions in the link above. Fuel pressure @ idle is now a steady 56psi instead of the slightly fluxing 70psi it was at before. The Haynes manual states fuel pressure should be anywhere between 53 - 63psi so, Good to go!
Old Oct 12, 2013 | 03:41 PM
N8Deezy's Avatar
That's the pressure without the vacuum hooked up correct?
An external FPR should read in the 40s with all the vacuum line connected. If the pressure is set to 50 with the line connected I would suggest removing it and verify the reading then reconnect.
Old Oct 12, 2013 | 04:31 PM
joeb1983's Avatar
G35
I'm still rocking the oem FPR in the tank/pump housing as I did not convert it to a return style system. Not over 400whp (334whp on a Mustang dyno, so roughly 370ish on a DynoJet give or take) due to it being a stock bottom end, so no need to spend the $ and convert... The direct reading gauge is just installed on an sandwhich style adapter. Like AAM's. That thing that looks like a FPR above the gauge is actually a "fuel pulse damper".
I drilled the swirl jet out to .070 with a #50 drill bit (had to order) and the oem FPR with a 7/64" bit per CJ Motorsports directions. Worked like a champ and my tuner said perfect! Now we can dial in those AFR's.
Old Jul 17, 2014 | 01:40 PM
black_gst's Avatar
anyone have a working link to the how to for drilling out the swirl ring and the rest of the instructions from CJ motorsports?
Old Jul 17, 2014 | 02:32 PM
N8Deezy's Avatar
Just checked the tech section right now. Everything loaded fine... http://tech.cj-motorsports.com
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
9tray turbo
Sep 29, 2015 10:22 PM
aaron3719
Sep 29, 2015 10:12 AM
Hogbone
Sep 28, 2015 06:44 PM
