06 g35 coupe equipped with smart key fob
Old Nov 14, 2013 | 11:32 AM
Hogbone's Avatar
Ok on the Exterior door handles there are buttons, one on driver side and passage side door handles.. Now these buttons lock and unlock the car doors, passages side door button works, the driver side button does NOT. Can anyone point me the right Direction as far as how to fix this. Thanks!
Old Nov 14, 2013 | 11:38 AM
WhosUrBuddiee's Avatar
Check the electrical service manual. Get the wiring diagram and check each point until your find the problem.
Old Nov 14, 2013 | 11:51 AM
Here is the appropriate section.
http://psedog.com/cars/fsm/g35/coupe/2006/bl.pdf
The door locks do not have fuses so the only thing it could possibly be is loose connection, short, or antenna failed.
I guess there is a chance it could just be programming failure. Go on youtube and look up steps to reprogram the remote and try that first.
Old Nov 14, 2013 | 12:49 PM
Hogbone's Avatar
Thanks lot man!
Old Nov 16, 2013 | 03:16 PM
Hogbone's Avatar
Man this a one hell of a DIY. The easy part is checking the Intelligent key Module but to check the swith itself is where it gets tricky. I have to everything that has to do with the freaking window, why, because it all attached to the access panel on the dang door! Now I know why infinite charges an arm and a leg to work on their cars... But fear not! I will try to do this on a not so rainy day.
Old Nov 17, 2013 | 01:24 PM
05_SkylineSedan's Avatar
20 Year Member
Before you tear the door apart you may want to inspect the wires as they pass through the hinge area of the door. (I think you can pull the rubber cover and get to them without disconnecting everything.) If you think about it, these wires get moved every time you get in and out of the car so it is possible for them to simply give up at some point. Many here have dealt with this problem with the trunk lid harness for the same reason (those get bent even further).
It's hard to tell from the diagram which wire color to look for in that harness but it may be worth inspecting before you start disassembling the door. Did you say I-key? if so, there is also an antenna in the same area so it has wires passing through that same harness.
Beyond that, there is also a way to check the switch circuit from where it connects to the BCM, but that would probably just confirm what you already know - not working.
Old Nov 17, 2013 | 05:26 PM
Hogbone's Avatar
Yea I found the wires that are for the door request switch and the wires that go the the door handle antenna. They split of from the main harness and of course they are taped up and I can't reach my fat hand in the hole to see what color the wires are. So testing the switch at the main harness as it goes in the door is point less, but I could still look to see if any wires are broke
chinee
Jun 10, 2024 07:48 PM
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
apintojr
Jul 23, 2015 10:52 AM
