How can I break into a G35 Coupe?
Old Sep 15, 2014 | 11:56 PM
bluedevils95's Avatar
Glad you got the door open. Sucks that you had to go through that
Old Sep 15, 2014 | 11:59 PM
saywat?'s Avatar
Anyone kno if the "frozen" issue is possible with the OEM actuator. Or its designed to always work with the key Atleast. I'd never do the $5 mod lol.
Old Sep 16, 2014 | 12:39 AM
JOKER's Avatar
CLUB MODERATOR
Originally Posted by redonblack35
After work I tried it out and it worked! 2mins and I was able to open the stupid door. It seems like JOKER said, the cheap actuator rod's screw thing slipped. I am going to put a small square of rubber to help with friction so that this garbage doesn't happen again. I hope that the keywords in this thread will help those with the same problem in the future.
Just use some epoxy on the screw . Simply mix some epoxy and stuff it in the hole, put the rod in and tighten the screw. Let the epoxy dry and I think you shall be fine.
Probably will not be able to take it apart next time. Hopefully there won't be a time when you'll have to do that.
Btw, you welcome for the suggestion. I spent few hours figuring out the issue and how to get to it
Old Sep 16, 2014 | 12:46 AM
saywat?'s Avatar
How hard was it to unhook the top of the door panel from the top of the door frame?
Old Sep 16, 2014 | 10:15 AM
JOKER's Avatar
CLUB MODERATOR
It's not that difficult.
Pop it up from the lock edge and then just keep going the length of the entire door. Helps if you use some sort of plastic prying tool.
I pried it up with a screw driver and then used thin piece of wood to pry the rest of the door and avoid unnecessary scratching and damage to the door or the panel.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
apintojr
Jul 23, 2015 10:52 AM
