Door switches, horn, headlights, tail lights problem
Old Mar 30, 2015 | 03:18 PM
mike730's Avatar
I have a 2003 g35 coupe. I bought the car when it was stripped down to be used for a kit car project. My issue is that my tail lights, front lights, doors, trunk switch, horn do not work. I have tested the bulbs and they work. I have tested the ends of each component to see if they are getting power and they are. I have replaced every fuse in the car. I have checked the IPMD the fues box under driver side and the second fuse box in the engine compartment.
I do have two code error U1212 and U1001.
Where are the CAN Communications lines H/L located and am I able to test them. Also am I able to test the BCM. I thought maybe it was communicating in some type of way to turn the items on. My reverse light works with no problem.
Also is there a ground that comes from the ECU.
The car starts with no problem
Old Apr 4, 2015 | 05:05 PM
rsantmyres's Avatar
Check the third fuse panel under the windshield behind the battery
Ludz
Lights
Mar 28, 2016 02:06 AM
JG_G35
Lights
21
Sep 14, 2015 02:00 AM
roboeclipse
Lights
Aug 13, 2015 10:45 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
