'03 G35 coupe won't start
Old Jul 2, 2015 | 08:40 AM
danpjenz's Avatar
My '03 G35 coupe tries to crank but won't start. This is a new issue. A few days ago most of my gauges quit one after the other, the car began shifting early and hard, the slip and vdc off lights came on, the gear indicator became intermittent, the at check light would come on and the lights on my console would flicker out. Seemed like my car had a poltergeist. The next morning, the symptoms disappeared. The next few days, my car would attempt to crank but not start. I would jiggle the keys and then it would start. After two days of those symptoms, my car would either crank and not start (& I'm talking a very small and short crank), or it was a no crank, no start (that varied). Any thoughts?
Old Jul 5, 2015 | 11:58 PM
Kevin Cannon's Avatar
Well I had a issue of my mass air rubbing my ac line blowing a fuse in the box behide the battery and I had kinda the same issues u have.
Old Jul 6, 2015 | 06:47 AM
danpjenz's Avatar
Responding
Thanks, Kevin. I'll check the fuses. I was told my ignition switch was loose and might be experiencing some grounding issues, so I ordered a new switch. It would be nice for it to only be a fuse. I'll let you know after I get a chance to look into it today.
Old Jul 6, 2015 | 01:03 PM
There was also a big ground issue I read about. I read that some g35s wouldn't start and they added new grounds to the motor and added a few extra ones and fixed the problem and got a better shift for auto.
Old Jul 7, 2015 | 08:03 AM
danpjenz's Avatar
Thanks Kevin. I'm guessing I'll need to take it to an Infiniti dealership for that?
chinee
Jun 10, 2024 07:48 PM
newbdriver01
Jul 16, 2015 11:35 AM
