G35 horn not working after getting A/C tested
Old Jul 25, 2015 | 01:54 PM
Rehman2009's Avatar
Hey guys
So the A/C in my 2003 G35 Sedan would become warm when I would idle so I took it to a shop. He decided to look at it and came to the conclusion that my A/C Compressor is weak and needs to be replaced.
Anyways, the next day, I notice that my horn (chirp when locking car) is weak. So I tried the actual horn and it is very weak (we already have pretty quiet horns). It's like only part of the horn is working or something. I have no idea lol.
It's odd because this was right after getting the AC looked at. He claims that I need a new horn and he didn't do anything.
Could it just be a loose wire or something?
Thanks!
Old Jul 27, 2015 | 01:35 AM
Urbanengineer's Avatar
If you look straight down when you pop the OEM hood up, you will see two snail like things. Check the wiring ok those and make sure they are well plugged in.
Old Jul 27, 2015 | 02:21 AM
Rehman2009's Avatar
Thanks! Could you tell me exactly where? Like directly around the middle once I open the hood?
Old Jul 27, 2015 | 03:23 AM
05_SkylineSedan's Avatar
20 Year Member
Here's a pic. Instructions say "remove grill" for access. Probably one of the two got disconnected. Makes a pretty weak sound when that happens...
Attached Thumbnails G35 horn not working after getting A/C tested-03-horn.jpg
champppy
Mar 31, 2020 12:25 PM
yassy
Aug 3, 2015 12:24 AM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
