over heating problems. 04 g35 coupe
Old Aug 8, 2015 | 11:05 PM
Smittie20's Avatar
What's up everybody. I have replaced my cooling system (radiatior, thermostat, water pump) and passed a head test. My car still over heats if I drive it for a long time. It burns through coolant also. I have zero idea what the problem could be. Maybe a hose? Please, any help will be great. Thank you
Chris
Old Aug 8, 2015 | 11:21 PM
ScraggleRock's Avatar
Performed a pressure test on the system and cap?
You most likely still have air in the system. Going thru coolant means a leak tho. You need to pressure test with a free autozone rental tool.
Old Aug 9, 2015 | 04:08 PM
Smittie20's Avatar
yes we've done that and have a new cap on it. Also have bled the air out of the system. I believe there is a crack in the head somewhere. I could be wrong?
Old Aug 9, 2015 | 04:29 PM
If you pressure tested it and it held pressure, you shouldn't have a head gasket leak. I would get the pressure test tool again and check your new cap, and repurge the air that may be left in the system. These cars are notoriously hard to purge of all the air.
Also, check your overflow tank and cap and all hoses for cracks/leaks.
Also, when it overheats are you moving or idling? If it's overheating at idle, maybe your fans are failing to turn on. Or maybe only one is coming on.
arora_g35
Apr 16, 2026 02:52 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
newg37
Jul 26, 2015 09:32 AM
laksjd84
Jul 24, 2015 05:12 PM
vstypicals
Jul 20, 2015 10:55 PM
