Low idle/relearn after battery disconnect?
Old Dec 17, 2015 | 03:05 AM
Rawrster's Avatar
G35 coupe 6MT Brembo Premium
I've had my battery negative disconnected and reconnected within the course of a couple days while installing and troubleshooting my new headunit. As a result, my ECU was reset and my car had trouble re-learning it's idle, so I was stalling on warm-startups. I took it to my mechanic to get the idle manually reset/relearned, while also getting my throttle body cleaned (it was completely black when he looked at it) and now the stalling is gone and the idle is getting better.
But the problem is, I'm still not done with my headunit install and I'm afraid that after leaving the battery negative unplugged again, that my low idle/stalling will return. My mechanic said that there's a good chance that I will encounter the low idling/stall problem again if I disconnect my battery(reset ECU).
Am I unlikely to short-out/fry anything if I continue to work on my headunit with the battery still connected? The only things I need to do is reconnect the factory Navi system, ground a wire that I forgot to ground, and connect the Axxess ASWC interface to keep my steering wheel controls with the new headunit. I'd hate to either go back to my mechanic and pay to get the idle reprogrammed to get rid of it right away or wait weeks for my car to re-learn the idle on its own... provided it happens again.
Old Dec 17, 2015 | 04:15 AM
Lartytiejdke3's Avatar
Do the relearn yourself
Search g35 idle relearn aka pedal dance
Old Dec 17, 2015 | 09:49 AM
LoSt180's Avatar
Disconnect the battery if you have to splice any wires. If you're just unplugging harness connectors, you'll probably be just fine.
If you have a bluetooth OBDII dongle, you can use the Nissan DataScan II app to do the idle relearn. Push a button on your phone, no fancy pedal dance needed. But the pedal dance works also, and is free.
Old Dec 17, 2015 | 10:16 AM
this i did not know!
nice
Old Dec 17, 2015 | 11:48 AM
LoSt180's Avatar
nice
So much easier than the pedal thing. Just make sure the car is fully warmed up by driving around for 10 minutes.
Old Dec 17, 2015 | 12:12 PM
Rawrster's Avatar
I'd like to try that app, but it seems to only support Android. I'm an iPhone user :P Guess I'll try the pedal dance if I have to. Thanks
Old Dec 17, 2015 | 07:28 PM
saywat?'s Avatar
why not jus disconnect the batt when u do the install instead of all night/day jus waiting. ive had mine unplugged for couple hours and my car was fine.
Old Dec 18, 2015 | 01:59 AM
Urbanengineer's Avatar
Buy a cheap android tablet for these things.
Hnm_2014
Oct 25, 2015 08:20 PM
andre6191
Engine - Intake/Fuel
Oct 14, 2015 09:20 AM
skiefer
Oct 5, 2015 09:24 PM
Usman Ali
Oct 4, 2015 08:23 PM
