random scraping noise
Old Jan 5, 2016 | 01:48 PM
vk45de's Avatar
So I have this 2003 sedan that is randomly making this scraping sound that sounds just like when you've grounded your bumper going into a dip that's too deep..... the thing is it even does it on completely level ground.
Old Jan 5, 2016 | 02:32 PM
Lartytiejdke3's Avatar
Ok
From where
Old Jan 5, 2016 | 02:41 PM
JG_G35's Avatar
Have you looked under your car? Maybe it's your wheel well splash shield or undershroud, it's fallen on me before so it might be that.
Old Jan 5, 2016 | 02:55 PM
vk45de's Avatar
From the front half - can't pinpoint with any accuracy as it comes on randomly and only lasts less than a second. It's always like WTF was that.
Old Jan 5, 2016 | 05:55 PM
Texasscout's Avatar
you need one of these stickers on the back:
Old Jan 10, 2016 | 01:09 PM
gillywig2's Avatar
Does it happen just after starting the car and moving off? If so, it could be the abs self testing.
Old Feb 21, 2016 | 10:35 PM
KaneAlt's Avatar
Made my day Tex. I have an issue like that but it's coming from my front driver side wheel. I'm thinking wheel bearings? Not sure...
Old Feb 21, 2016 | 11:29 PM
vk45de's Avatar
Not the wheel bearing dude. I've actually just had 2 cars with bad wheel bearings, it's not random. Bad bearings make a droning noise that increases with speed that sounds like bad tires. The speed/frequency relation is linear as you'd expect.
Old Feb 21, 2016 | 11:35 PM
KaneAlt's Avatar
Does your steering vibrate? Did you check your brakes to see if you have worn calipers?
Old Mar 2, 2016 | 06:47 PM
Mignav01's Avatar
Is your parking brake stuck? could be its barely making contact and causing the scraping nice that you only hear while going slow?
aznvictobear
Feb 7, 2016 10:32 PM
mattdg35
Jan 14, 2016 02:55 PM
G35_ariel
Jan 7, 2016 10:06 AM
metallideth
Jan 5, 2016 01:11 PM
ReaverG35
Dec 31, 2015 10:10 PM
