Ac suddenly stopped working
Old Aug 11, 2016 | 09:00 PM
Mat Lyons's Avatar
Hi,
05 g35 sedan. Drove 38 mIles to work. Air was ice cold as always. 9 hours later, it blows but not cold. Not even a little. Fuse? If so which box is it in?
I looked in both and can't find one labeled ac
Thanks!
Old Aug 11, 2016 | 09:38 PM
Xanoz's Avatar
Originally Posted by Mat Lyons
Hi,
Thanks!
Do the fans blow but no cold air?
Old Aug 11, 2016 | 09:41 PM
Mat Lyons's Avatar
Exactly.
Old Aug 11, 2016 | 09:56 PM
Xanoz's Avatar
Exactly.
Have you gotten behind the cigarette lighter at all?
Old Aug 11, 2016 | 09:57 PM
Mat Lyons's Avatar
No sir
Old Aug 11, 2016 | 09:58 PM
Xanoz's Avatar
No sir
Automatic or 6mt?
Old Aug 11, 2016 | 10:00 PM
Mat Lyons's Avatar
Auto
Old Aug 11, 2016 | 10:07 PM
Xanoz's Avatar
No sir.
Does the radio work?
Old Aug 11, 2016 | 10:08 PM
Mat Lyons's Avatar
Perfect. Nothing different but warm air.
Old Aug 11, 2016 | 10:17 PM
Xanoz's Avatar
I don't know what to tell you then, definitely not the same problem I had. I blew the radio fuse on my 05 6mt coupe and had to replace it for ac to work. Sorry man I hope you find help
Old Aug 11, 2016 | 10:23 PM
Mat Lyons's Avatar
Well, thanks for looking. Could it be a fuse, or no since it's still blowingoing? Iow is the ac strictly mechanical since it's belt driven.
Old Aug 11, 2016 | 10:32 PM
Xanoz's Avatar
Only thing I can thing of is the radio fuse since it's wired together. That's a cheap thing to fix you could try but I'm not sure if that's it
Old Aug 11, 2016 | 10:36 PM
Mat Lyons's Avatar
Thanks buddy.
Old Aug 12, 2016 | 10:45 AM
Mat Lyons's Avatar
Anyone else that may be reading. Input is appreciated.
I just got in my car with the AC off. Then let it idle for a minute. When I turn the AC on, the tach will move a smidge, VERY LITTLE. But it does move, so I am guessing it is kicking on. It is nothing like my Honda where you can feel when it kicks on, but I am guessing this being a higher end car it wouldn't be as noticeable.
Any help?
Old Aug 12, 2016 | 11:02 AM
coffeysm's Avatar
Turn it on and check out the compressor to see if the clutch is engaged. You should also be able to hear it going on and off.
