Disable Driver Side Airbag?
I've been researching but haven't come up with an answer: Is there a way to disable only the steering wheel airbag without throwing the light?
I'm 4'11" and should the airbag go off, it could actually kill me. I do want the other airbags functional in the event of a crash, however.
It would be better of you could figure out a way to be further from the wheel. For instance, there are companies that make pedal extensions. To answer your question (without suggesting you do the following) Google "replace airbag with resistor".
I had seen mixed reviews on the resistor and the SRS light. Thanks for the info though!
The non-adjustable pedals is the real issue. There used to be a company that made legal pedal extensions, the premium package seat can be raised to a safe height or the overall track can be shimmed for the non-height adjustable ones.
Disabling the SRS is not a good answer.
If the resistor option doesn't trigger a light, I'm likely going to try that, or I will get an aftermarket wheel and forego all the nice creature comforts.
The disability vehicles I've seen in the past still had a functional airbag, the pedal extensions and seat height adjustment were the only mods. I work with a man who's only about 4_1/2' tall and it's the same setup he was in his car.
