03 g35 coupe passanger seat stuck forward won't slide back
Old Dec 8, 2017 | 06:25 PM
Ito123's Avatar
I removed my seats and my passanger seat switch is broke when I put seats back in the passenger seat is suck all the way forward won't slide back
Old Dec 8, 2017 | 07:22 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Remove the front seat panel plastic to access the transfer mechanism and motor, remove it and use a 10mm to manually move the tracks back to a comfortable position, you need to move each side evenly so it will slide or go back and forth on each side a little.
​​​​​​It works in a pinch until you can troubleshoot and replace the broken components.
Old Dec 8, 2017 | 08:15 PM
Ito123's Avatar
There was nothing wrong with the seat other than the switch being broke I used to slide back and forth fine , will I fix after manually bribing it. Back
Old Dec 8, 2017 | 08:18 PM
cleric670's Avatar
BANNED!!!
Yes, manually bribing it will fix.
Old Dec 8, 2017 | 08:57 PM
G2B35AGN's Avatar
About six C-notes ought to get that seat to cooperate.
Old Dec 8, 2017 | 09:18 PM
Ito123's Avatar
I will post more later on almost finished , customizing interior, gonna go for black with read leather some carbon fiber and more
Old Dec 8, 2017 | 11:11 PM
cleric670's Avatar
BANNED!!!
I approve of the door conversion but holy cow those must be some seriously beefy brackets. Those doors are HEAVY!
Old Dec 14, 2017 | 05:11 AM
Blue Dream's Avatar
I drove ttrank's car solo
Sweet mother of Jesus, I can not approve of the doors. One of the most horrendous mods you can do to a G, right up there with the GTR front bumper.
Old Dec 16, 2017 | 11:16 AM
cleric670's Avatar
BANNED!!!
I mean it would look better with a full widebody kit, if you're gonna go big then make it HUGE!
Old Dec 16, 2017 | 12:05 PM
Ito123's Avatar
Yea the brackets are pretty beefy , those are my intentions tho to put the wide body kit little by little slowly but surely , I'm having a new issue Thoughi removed the center console so It can be wrapped in carbon fiber , and when putting it back in I gently tapped the plastic and my gps screen turned off won't work and the disk won't eject
Old Dec 16, 2017 | 12:51 PM
cleric670's Avatar
BANNED!!!
Probably dislodged or pinched a wire somewhere.
Old Apr 12, 2019 | 03:26 PM
floydb's Avatar
red 4 door, automatic, leather, phone
No wonder it's not working; you need an extension cord to plug it back into the harness!
