Clicking with recirculating AC on
Old Sep 5, 2018 | 12:34 AM
Karambwan's Avatar
Exclamation Clicking with recirculating AC on
Hello guys!
This is my first time posting, sorry if this isn't the right place to post this thread.
I have a 2005 Automatic G35 Coupe and recently I've had a problem with my AC system. When I turn on recirculation, there would be a clicking sound coming from the passenger side of the dashboard. If anyone has any idea please help!
Thank you very much! The google link below is a video showing the issue.
Sorry again if this has been resolved in the past already, I didn't know how to find it.
https://drive.google.com/open?id=1FT...ftaxmZJuhs92Wh
Old Sep 5, 2018 | 02:41 AM
FreshLikeAG's Avatar
Blend door actuator. Probably the one behind the glovebox
Old Sep 5, 2018 | 03:59 AM
Karambwan's Avatar
What do you think the solution is? What should I do? o:
Old Sep 5, 2018 | 12:03 PM
You'll have to remove at least the glove compartment and probably the head unit assembly. Remove the glove compartment and locate where the noise is exactly coming from. You should be able to feel the blend door actuator clicking. The actuator has a gear made of plastic and the teeth will strip and stop engaging. Once you find the part, get the part number and buy a new one. Part #9 in the diagram
Old Sep 5, 2018 | 03:11 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Take off the cabin air filter and see what's blocking the fresh air blend door. When that clicking sound happened to me it turned out to be the positive battery cover fell off and went down into the cabin filter area.
Old Sep 5, 2018 | 05:35 PM
Karambwan's Avatar
Thanks alot, I'll work on it tomorrow and see how it goes
Old Sep 6, 2018 | 08:18 PM
Urbanengineer's Avatar
Good idea!
Thanks to the original guy who replied about it.
Old Sep 7, 2018 | 11:30 PM
Karambwan's Avatar
Thanks for the help guys!
While at it, I also changed the cabin air filter and it looks like a ga damn mop was stuck in it.
This was the thing that blocked the air blend doors from closing causing the clicking sound.
Old Sep 8, 2018 | 11:48 AM
Well damn, how the hell did that get in there?
Old Sep 8, 2018 | 12:09 PM
herrschaft's Avatar
You're not supposed to clean those filters with a mop...
Old Sep 8, 2018 | 03:50 PM
Karambwan's Avatar
No idea, probably previous owner. But it's been in there for years, clicking only happened recently.
Old Aug 5, 2020 | 07:10 PM
jeasley's Avatar
No Description
Do you have the part# of the blend door actuator? Did you purchase from Infiniti or box store?
Old Feb 16, 2025 | 04:21 PM
Jchag28's Avatar
G37xS
Same problem
Originally Posted by Karambwan
Hello guys!
I have a 2012 g37xs same noise from the passenger side with the same thing when the recirculation is on I have the part to replace it.... did you do it yourself was it hard ? How long did it take ? If not how much did someone charge to fix that ?
Old Feb 16, 2025 | 05:24 PM
Karambwan's Avatar
I didn't actually replace anything. For me, it was just something blocking the actuator door and I was able to correct it myself. Maybe check if there is something blocking it first before replacement.
Best of luck
Old Feb 16, 2025 | 05:58 PM
Jchag28's Avatar
G37xS
Thanks
Best of luck
how was the process getting to it ? Just drip 5he glove box and it's right there ? Hopefully I'll get to it tomorrow all this damn snow and I can't defrost my car without clicking lol
