got the driver door lock actuator, need help with install.
Old Jan 1, 2006 | 08:52 PM
imRACERX's Avatar
So the piece looks easy to install but i guess getting to where it needs to go is the complicated part. Its the Door lock actuator (motor) for the driver side. i was told by removing the second door panel i can access the DLmotor however taking that second door panel of is not easy because the window up down track and other parts are connected to it. Once all the 1o or so screws are loosened, the panel puls slightly appart and then gets stuck at about an inch of the door, it seems to be bolted onto the window unit parts ans wish i could have one of you tell me how. speciallyt if you have a CHILTON book or some other manual. HELP! thanks RX
Old Jan 2, 2006 | 02:01 AM
G352NV's Avatar
Never enough
Take the panel off there will be black covers over holes, I think two of them. Remove them, now you will have to roll the window up or down a bit to see the 10mm nuts. Once you can see em remove them. The window will pull straight up and out. Now remove the second panel. There is about 15 10mm screws that hold it on. After that is removed everything else is cake! Its prett easy really.
Old Jan 2, 2006 | 07:36 PM
imRACERX's Avatar
damn man, i will give it a try tom daylight and get with you. thanks man! BTW the the black covers over holes; are they black circular decals covering holes where nuts are inside?
also " Once you can see em remove them. The window will pull straight up and out." means what? You mean the whole window comes out completely? I just dont want to remove it and then have trouble getting it back on.
also you say 15 screws that hold what on? because the actuator i dont believe can hold that many screws. its actually the size of a small hand and white plastic. please help thanks RX
laksjd84
Feb 28, 2026 01:58 PM
mike730
Jan 12, 2018 04:25 PM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
