The Great G35 Banner Relay! Help us move our banner coast to coast!
tunning for g35
Old Feb 13, 2021 | 11:08 AM
Bilal Barakat's Avatar
Infiniti g35
Exclamation tunning for g35
want to ask about the different between the remap and the tune any idea ??
Old Feb 13, 2021 | 11:40 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Same thing, messing with the fuel and timing maps IS tuning. Basically any modifications to the factory programming is "tuning" but typically the term is reserved for actually manually editing the fuel map not just a "plug in tuner" which often times is just a timing map change and sometimes adds other functionality that didn't exist with the factory tune.
The tune is "flashed" onto the engine management computer (ECM/ECU/whatever the manufacturer decides to call it) by interfacing through the OBD2 diagnostic port.
Plug-in tuners on SOME vehicles also affects the fuel map, but it's a generic tune that doesn't vary from one car to the next.
CUSTOM tune is when someone logs the data for your exact vehicle (plug in a laptop, go for a drive) and edits the base tune to give your engine EXACTLY what it needs.
Plug in tuners also tend to be more destructive to the engine since they are typically just a degree or more of timing and can lead to engine detonation.
Custom tune actually makes the engine run BETTER than it does on the OEM tune.
Our option for a custom tune on the G35 is the UpRev tune, if you're interested in an e-tune send a pm to @seymore4 for more info or check out his thread in the engine/tuning section. Lots of questions already answered.
https://g35driver.com/forums/tuner-d...6-uprev-q.html
Old Feb 13, 2021 | 11:42 AM
seymore4's Avatar
m56
Its just two ways to say the same thing. When you "tune" the car you are "remapping" the computer
Dio23
Nov 7, 2019 04:43 PM
LilWest209
Tuner & Dyno
Aug 24, 2015 02:00 PM
G-TWIN
Tuner & Dyno
Jan 7, 2009 06:06 PM
brent460
Apr 12, 2008 11:07 PM
