KPtechnologies Mirror Tilt Module Group Buy
Old Nov 8, 2007 | 10:04 PM
KPierson's Avatar
Originally Posted by kyu1021
can i apply my discount to your push button start?
This discount only applies to modules that are currently for sale, not ones that will be available in the very near future!
Old Nov 8, 2007 | 10:09 PM
V35 Skyline GT's Avatar
6MT Coupe
Is the purple wire for reverse input there on 6mt's like 5at's?
Old Nov 8, 2007 | 10:30 PM
KPierson's Avatar
Yes, both cars have reverse lights that can be tapped in the drivers kick panel.
Old Nov 9, 2007 | 09:00 AM
KPierson's Avatar
I posted about this over at my350Z.com so hopefully we can get some more people involved!
Old Nov 9, 2007 | 09:35 AM
6MT Coupe
Very good, thanks for confirming that. Going to your site now to order
-edit- whats the brake by-pass module about?
Old Nov 9, 2007 | 10:41 AM
6MT Coupe
order placed:
1. sansin
2. Retzius
3. afr0puff
4. g35man04 (deluxe mirror tilt and Window-up module)
5. aenokea
6. 06CPV35 (MT30D + NM20; SM20; SR20; DL20; RP20 and SS20)
8.
9.
10.
11.
12.
13.
14.
15.
16
17.
18.
19.
20.
Old Nov 9, 2007 | 02:12 PM
dcutz21's Avatar
order placed:
1. sansin
2. Retzius
3. afr0puff
5. aenokea
7. dcutz21 (deluxe mirror tilt down)
8.
9.
10.
11.
12.
13.
14.
15.
16
17.
18.
19.
20.
Old Nov 9, 2007 | 02:50 PM
G35UKY's Avatar
Hey, KP, will this module work on '07 G35x? I didn't know if it would due to having two different driver memory positions which changes the mirror settings as well.
Old Nov 9, 2007 | 03:15 PM
KPierson's Avatar
It should technically work, but it would only work in one position or the other. This is simply because the module is time based and one time setting won't work for the two different positions if the positions are drastically different.
Old Nov 9, 2007 | 03:58 PM
oscottio's Avatar
order placed:
1. sansin
2. Retzius
3. afr0puff
5. aenokea
8. oscottio (tilt + window roll up)
9.
10.
11.
12.
13.
14.
15.
16
17.
18.
19.
20.
Old Nov 9, 2007 | 04:24 PM
G35UKY's Avatar
KP, also does the Deluxe (2 mirror) control both mirrors at once, or can you put the mirror selector switch to the one you want to tilt? Is there also a way to make both or neither tilt when in reverse as well? Please let me know so I can pick out the right one and order it.
Old Nov 9, 2007 | 04:37 PM
g35man04's Avatar
CLUB MODERATOR
so just to clarify KP when i put my car back in drive after the install of this my mirrors will go back to where they were at originally?? correct? I bought the deluxe for my 04 coupe
Old Nov 9, 2007 | 05:34 PM
KPierson's Avatar
The deluxe version tilts both mirrors or neither mirror (there is a bypass method for the times you don't want the mirrors to tilt).
You can install a special switch to add control for either left or right. PM me for more info on switch.
Old Nov 9, 2007 | 05:37 PM
KPierson's Avatar
Yes, approximately 1 second after the car is placed in reverse the mirrors will tilt X amount of seconds (X is programmable from ~1-5 seconds) Approximately 8 seconds after the car is taken out of reverse the mirrors will go up X + Y seconds (Y is programmable -1 - 1 second). The 8 second delay is to prevent the mirrors from going up and down while parallel parking.
Old Nov 9, 2007 | 06:13 PM
  #30
g35man04's Avatar
CLUB MODERATOR
okay perfect!! thanks man!
