Hotchkis Sport Sway Bar Set G35X AWD 04-06
Old Aug 22, 2012 | 04:42 PM
Coz@Czp's Avatar
Due to limited space in the warehouse we have decide to do a group buy on the Hotchkis sway bars for the 04-06 G35X AWD. If I get 5+ buyers on these price will be set at $340 shipped.
Enhance the cornering performance of your G35X with a set of Hotchkis Sport Suspension sport sway bars. Our sport sway bar package increases front/rear roll stiffness giving the car crisp, quick turn-in response and balanced handling. As delivered the car has slight under steer and limited roll control. Sport sway bars give the driver the ability to rotate the car on corner entry and steer with the throttle when necessary. The dreaded under steer is eliminated and the handling becomes comfortably neutral with added traction during cornering. Hotchkis Sport Suspension sway bars feature a durable powder coat finish, greasable bushings, and brackets.
Item# 22444 fits 04-06 AWD G35X models ONLY. RWD Models use item 22441
Features:
• Lightweight, Durable 1 3/8" (35mm) Tubular Front Bar.
• Lightweight, Durable 1.125 (28mm) Tubular Rear Bar 3 Way Adjustable
• Premium mounting hardware including, greasable polyurethane bushings and heavy duty brackets.
• Finished in durable anthracite powder coat.
Benefits:
• Brings handling excitement to your G35X
• Dramatically improves steering and chassis response
• Increases stability, improves traction, reduces body roll by increasing front/rear roll stiffness
• Easy bolt-on installation.
Specs:
Front Sway Bar 35mm (Ø1-3/8") Hollow
+230% Stiffer than Stock G37
+205% Stiffer than stock G37S
+230% Stiffer than stock G37S
Rear Sway Bar 27mm (Ø1.063") Hollow 3 Way Adjustable
+120, 175, 250% Stiffer than Stock G37
+5, 30, 65% Stiffer than stock G37S
+50, 90, 145% Stiffer than stock G35S
PM me if you have any further questions
Old Aug 22, 2012 | 05:21 PM
MPG35fiend's Avatar
Finally!!
Old Aug 28, 2012 | 04:16 PM
Coz@Czp's Avatar
Thread Bump!!!
Old Sep 22, 2012 | 01:44 PM
Canadiotica's Avatar
Beauty to bad won't be getting these till next year
Old Sep 25, 2012 | 02:07 PM
Coz@Czp's Avatar
You can get these today. Pm me for the best price shipped you will be surprised!!!
Old Dec 11, 2012 | 01:26 PM
Coz@Czp's Avatar
Thread Bump
jsimonk
Dec 22, 2023 03:49 PM
Sepsis
Feb 12, 2020 02:05 PM
Th611
Oct 27, 2015 03:48 PM
wuppiedog
Aug 7, 2015 11:16 AM
vstypicals
Jul 20, 2015 10:55 PM
