///AIRREX Air Ride Suspension Kit Group Buy! Best Prices Ever!\\\
Old Aug 29, 2014 | 12:29 PM
NuGen Auto.'s Avatar
NuGen Automotive is NOW an Authorized Dealer for AIRREX Air Ride Kits! What better way to kick off our relationship with AIRREX than by offering a special Group Buy Price to the G35 Community.
The kit will include all necessary parts needed to be bagged out. Incase you didn't know AIRREX is the original Air Bag Suspension Kit and are the only ones that make a full kit with all original parts. They hold the patent for air ride kits. No other brand makes a full kit including there own struts besides AIRREX. With that being said lets kick off this GROUP BUY!!!
INFO ON THE KIT IS AT BOTTOM OF POST
MSRP - $5000 + $130-$150 Shipping - TOTAL $5150
If we can get 2 Buyers we will offer the entire kit for the special price of $4850 and well include shipping on us which is around $150
If we can get 3 Buyers we will offer the entire kit for the special price of $4800 shipped and well include shipping
If we can hit 5 or more Buyers we will offer the entire kit for $4750 shipped out the door! Thats a total savings of $400!!!!
BUYERS:
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
HERES SOME INFO ON THE KIT:
Vehicle Specific Upper Mount*
Every AirREX upper mount is CNC machined from 6061 aluminum and then hard anodized. High density polyurethane bushings and/or high performance bearings completes the package to ensure exact fitment and durability. These upper mounts not only simplify installation but also improve ride quality, handling, and help provide maximum drop by replacing the bulky OEM upper mount.
12 Clicks Adjustable Damper
A 12-way compression + rebound (together) adjustable damper is standard in every AirREX application. Each damper is matched to the air spring (bellow or sleeve) for the vehicle application and the user can further adjust for performance or comfort by the simple turn of a ****.
Double Convoluted Bellow
High durability 2-ply double convoluted air springs help provide both a comfortable ride at driving height and maximum drop when aired out. The size of the bellow is carefully chosen by AirREX engineers for each application to ensure correct spring rate and proper clearance for the vehicle.
Twist Lock Compression Fitting
Compression fittings are used to ensure a reliable leak free seal when used with 6mm or ¼ inch DOT nylon air tubing.
Fully Threaded Damper
Each AirREX damper is fully threaded to maximize adjustability similar to that of a coil over. Users can easily adjust for maximum drop or for maximum comfort at driving height by simply loosening the lower lock collar and turning the damper + air spring assembly up or down.
Vehicle Specific Lower Mount
Every AirREX application includes a vehicle specific lower bracket which is manufacture to exact OEM specification. Every tab or bracket for the hub, spindle, sway bar, brake lines, abs sensor, etc. is present to ensure proper fitment like that of the factory suspension. Some applications will include a high density polyurethane lower mount bushing.
Plur
Audio/Video/Electronics
Jun 1, 2020 08:25 AM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
ZacDesu
Jul 14, 2015 11:13 PM
