Hawaii Honolulu
motor question
Old Jun 27, 2008 | 05:26 PM
THE-G35's Avatar
motor question
i just took out my JWT pop charger and put in an injen CAI it was installed by sonics. however 2 days in a row i've been gliding down the pali in netural and once i go through the second tunnel my engine dies. my electrical and everything stays on however my power stearing and my break peddle lock up. thats 2 days in a row same place, same weather, same time. the first time i did it i questioned that maybe the chip was just reconfiguring itself but... 2 days in a row idk whats up.
any imput would be appricated. might call sonics back and see if they know whats up or i might put back in the pop charger...
never had this problem before. car only has 26k miles on it.
Old Jun 27, 2008 | 05:35 PM
Ready2Play's Avatar
the tunnel is against you......
Old Jun 27, 2008 | 06:53 PM
636Racer's Avatar
Reset your ECU and do the learning sequences as well.
Old Jun 27, 2008 | 09:41 PM
THE-G35's Avatar
is there a way i can do that without taking to the dealership to reset it?
Old Jun 27, 2008 | 09:52 PM
636Racer's Avatar
https://g35driver.com/forums/engine-drivetrain-forced-induction/6526-easy-ecu-resetting.html
Old Jun 28, 2008 | 02:41 AM
ak808's Avatar
maybe you had pork in the car.
Old Jun 28, 2008 | 03:07 AM
draco0858's Avatar
lol
Old Jun 29, 2008 | 03:48 PM
bluesi808's Avatar
+1 on the pork
Old Jun 29, 2008 | 04:47 PM
THE-G35's Avatar
actually that ecu reset worked really well. my car has way more power now then it did before especially saying that its relearning with the engine mods on there. thanks for the link. not sure if you went out in search of it but i appricate the time you put in for it.
Old Jun 30, 2008 | 07:50 AM
jdm-v35's Avatar
also just in case the reset doesnt fix the problem it sounds like they didnt hook up the breather hose underneath the intake pipe. it would cause the maf to read incorrectly and car to shut off. also would reduce intake pressure causing the brake system to have no vaccum.
Old Jun 30, 2008 | 04:33 PM
THE-G35's Avatar
yeah the reset didn't work. it happened again this morning same time same place. i'll check the hose later.
Old Jul 1, 2008 | 04:10 PM
636Racer's Avatar
Did you do the idle learn sequence?
Old Jul 1, 2008 | 04:19 PM
elayman's Avatar
also clean ur MAF sensor if you can't figure it out with the other things people posted here
jsimonk
Dec 22, 2023 03:49 PM
Gookiecrunch
Aug 19, 2015 12:00 PM
Feffman
Midwestern
Aug 16, 2015 08:08 AM
Feffman
Autocross/Road
Aug 16, 2015 08:07 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
