Hawaii Honolulu
any thoughts on this hyper voltage thing?
Old Oct 13, 2008 | 04:22 AM
FargoG35's Avatar
Iran into the guys from titan, whats the deal with this thing? Is it a scam or can it work?
Old Oct 13, 2008 | 04:50 AM
AllNatural's Avatar
well I see they are selling for 200 to 300 depending on where you buy from. Why dont you go to titan and ask them if they can straight dyno for you. If they are backing the product so adamantly then they should have no problem letting you try it out. As for me I will probably go the MSD ignition route with iridium plugs.
Old Oct 13, 2008 | 02:55 PM
M-azing.'s Avatar
they've got my dyno it worked on the 35, how it works is simply when cars are dyno'd at the factory they are running on volts, then when they get here there only running on 12 volts, all the thing does it pretty much gives u your horsepower back i saw a 10hp gain from it. and my dyno is there
Old Oct 13, 2008 | 07:24 PM
momonaboy's Avatar
i was wondering about this thing, if you up the volts on your battery, wouldnt you fvck up stuff like amps, ccfl ballasts (the one for my demons eyes), and other electronics that are made to run on 12 volts? because you basically up the volts on the battery. wouldnt that fry some stuff, just a thought.
Old Oct 13, 2008 | 07:30 PM
ttrank's Avatar
Grocery getter
I have this one:
http://www.sunautomobile.com/product...pervoltage.htm
Never did a dyno, I got it with their ignition amp at the same time 2nd hand. Can't say if it works or not for sure but I doubt it hurts.
Old Oct 13, 2008 | 09:28 PM
G35Five_O's Avatar
I had one on my 03 and just put it into my 07. i did it mostly because of all the equipment i run and need for work. I forgot what the experience was with the 03 but in the 07 the acceleration seen quicker and shift harder. This could also have happen when the battery is disconnected and the computer is being reset-ed.
The only reason i but it into the 07 was I was tired of it laying around the place.
It would be nice if it really gives the 10 more horses and torque.
Old Oct 13, 2008 | 11:50 PM
M-azing.'s Avatar
hasn't hurt anything electrical in my car yet, but as i said titian has my dyno and it shows 2 runs with it off and 2 with it connected
Old Oct 14, 2008 | 05:00 AM
momonaboy's Avatar
^ i was just wondering because most car electrical stuff run on 12v. i dont know if it would fry certain things.
Old Oct 14, 2008 | 05:36 AM
jdm-v35's Avatar
Not necessarily true. Average car voltage with alternator running is 13.5 to 14 volts. I think the most helpful thing is a grounding kit which would improve anything electronic. The only thing hyper voltage can really do is stabilize voltage. It doesnt hurt but i dont think it helps either.
Old Oct 14, 2008 | 10:29 AM
ttrank's Avatar
Grocery getter
The battery sits at ~12V when the car is off and when it's running the alternator charges the battery at about 14.4V.
Old Oct 14, 2008 | 08:58 PM
bluesi808's Avatar
just buy a tornado for your intake. lol.
Old Oct 14, 2008 | 08:59 PM
bluesi808's Avatar
what kind of dyno does titans have? did they do a baseline reading and then dyno it with the voltage system after? how many runs did they do?
Old Oct 15, 2008 | 01:24 AM
M-azing.'s Avatar
they took the car to munkyworks for the dyno, so and they did 4 runs its not hard to dissconnect and reconnect, thats what they did
Old Oct 18, 2008 | 12:06 AM
TonyG35DG's Avatar
Titan posted on Craig's list for under $200, might be worth checking out if it gives 10hp gain.
G35 +10 horsepower & 10 ft lbs of torque with Hyper Voltage
Old Oct 18, 2008 | 12:58 AM
ttrank's Avatar
Grocery getter
That dyno is tiny.
JoeMac
Aug 20, 2015 10:17 AM
Gookiecrunch
Aug 19, 2015 12:00 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
