Hawaii Honolulu
Need help
Old Jan 9, 2009 | 10:53 PM
SILEIGHTY's Avatar
Need help
I know it know it might sound dumb but i need help changing the high beam light bulb and the little bulb on the 04 g35 coupe
i look at it and it looks like i have to remove the bumper just to change the little bulb the side of the headlight and pull the head light out the change the bulb
anyone know a site that can help me thx
04 g35 coupe
Old Jan 10, 2009 | 01:08 AM
h2mann's Avatar
check the tech section under the lighting part, there are a bunch of how to's and instructions on headlight removal, bulb swaps etc. pretty helpful info in there.
Old Jan 10, 2009 | 01:28 AM
Jazielomar's Avatar
im gonna be doin it tommorow if u wanna come c... nits not that hard dnt even gotta remove the whole bumper....
Old Jan 10, 2009 | 04:28 PM
myroncuz's Avatar
for both bulbs, you can just pull the fender lining back. but yeah, check out the tech or diy section. should be handful of threads
Old Jan 10, 2009 | 08:14 PM
nutt's Avatar
what i did was i had to raise my car up since im lowerd and pulled the fender back. then all u do is unscrew the headlight balaster and switch the bulbs. hope this helps
Old Jan 10, 2009 | 08:20 PM
elayman's Avatar
its easiest (well may take longer, but not hard and you get lots of room) to jack the car up, remove the wheel, take the fender lining down, or remove it if you like, and then you can access your lights from there. I tried it while turning the wheel all the way inwards and it was a pain to reach in without clinking the bulbs on the side of the housing
Old Jan 10, 2009 | 10:32 PM
nutt's Avatar
^ha i was to lazy to remove my wheel when i did mine
Old Jan 11, 2009 | 09:09 AM
myroncuz's Avatar
man i so wanna switch out my fog lights already. but i plan on getting recon sometime soon after my drop so i guess ill wait til later since i can be somewhat lazy..
but good luck sleighty
Old Jan 13, 2009 | 03:03 AM
SILEIGHTY's Avatar
Thx guy i did it already all i did was turn the wheel one way remove the fender lining changed them in like 5min haha thx guyz
then did the same for the other side i mr is droped and i was lazy to jack it up so i just turned my wheel
