Hawaii Honolulu
Questions to Hawaii
Old Sep 29, 2010 | 04:28 AM
nate704's Avatar
Questions to Hawaii
I just picked up my car and I have a couple of questions.
1. OEM Navigation, Is there any way I can get it to work in Hawaii?
2. My compass shows" - - - " how to get it back to normal?
Thanks!
Old Sep 29, 2010 | 06:34 AM
jdm-v35's Avatar
probably press the compass button will fix that. i dunno if infiniti can update the software for the gps or not.
Old Sep 29, 2010 | 07:41 AM
Chuck D's Avatar
I am not sure if the OEM nav works in Hawaii according to the link here it dosent! http://www.navigation.com/is-bin/INT...MenuItem=FAQ#4
the dealership should be able to confirm this.
you could always go with a JDM DD kit and Aftermarket DD with nav my Z3 is awesome. wroks great.
Old Sep 29, 2010 | 12:24 PM
Meatshackle's Avatar
Deep Sea Moderator
1. 2003 GPS will not work in Hawaii.
2. You can calibrate the compass, check the manual.
Old Sep 29, 2010 | 12:44 PM
PR-G35Driver's Avatar
ho man where this guy come from...are u a new moderator??? nah jk
u gonna come to the meet tonight????
Old Sep 29, 2010 | 03:53 PM
G-gasm's Avatar
From one of my earlier threads: might help ya
The 07 coupe (which, based on the OP's mentioned of a DD kit) doesn't have an AV input for the stock nav.
back to the OP
I just left Hawaii, so I feel your pain. The stock screen won't be entirely useless, since you still can monitor maintenance and gas mileage info, but yeah, basically useless.
To get navigation on the stock screen, you've got a few options:
A) Garmin GVN53 + avelectronic adapter
This would probably be the most factory-like install, since it would be independent of the radio, and you wouldn't have to shop for your DD radio based on navigation functionality. I'm not sure how expensive the avelectronic adapter is, but between the two devices, somewhere around $600 would be about right.
B) Double Din Navi + avelectronic adapter
Most DD navis have a video output, so you'd be able to display the same screen to the more visible popup screen. Since you're planning a DD conversion anyway, this is probably the best way to re-use the factory nav. You'd be tied to DD radios that include navigation (which still gives you a lot of options) but most of the best DD radios have navigation anyway, so this is still a good option, and lets you use the touchscreen on the aftermarket DD radio/navi instead of the remote with the GVN53.
C) Any aftermarket Garmin + a suction cup mount
Pop the navi up and use an windshield mount to stick it in the stock position. It's cheap, it works, and it's easy.
D) DD Navi + ignoring stock system
Less expensive than using the avelectronic adapter, but doesn't put the screen where you can see it. You can always add the avelectronic adapter later if you must have it on the popup screen.
Old Sep 29, 2010 | 11:35 PM
GZire's Avatar
OEM works in Hawaii, but mine is a '09 vintage.
Old Sep 29, 2010 | 11:38 PM
GZire's Avatar
^^^BTW Nissan not Infiniti.
Old Oct 1, 2010 | 12:32 AM
Chuck D's Avatar
thats dumb the Nissan Nav works and not the infiniti
Old Oct 1, 2010 | 12:33 AM
Neu Era's Avatar
Isn't Hawaii small enough not to need NAVI? lol jk.
Old Oct 1, 2010 | 01:01 PM
GZire's Avatar
^^^Pretty much. They are islands too, so it's not like you'll end up in another state. lulz
Old Oct 1, 2010 | 01:26 PM
Neu Era's Avatar
Lol.
Old Oct 5, 2010 | 01:07 AM
Deep Sea Moderator
I've lived here almost 5 years and still get lost.
Sick of my $2,000 trip computer.
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
