Hawaii Honolulu
HKS HyperMax RS installed...
Old Apr 13, 2005 | 04:47 AM
jdbinspired's Avatar
Unhappy HKS HyperMax RS installed...
dang guys ... just finished installing the coilover kit... and DANG... my car is freakin' high... I haven't test drove the car yet... too late already... but hopefully the ride is nice... I have to find a way to make the car slamm... dang... all SICK...
Old Apr 13, 2005 | 06:30 AM
beangrower's Avatar
are those the one that was on these forums for 1500? if so, damn...i wanted those. can't afford'em though DId you crank it all the way down? post pics.
Old Apr 13, 2005 | 12:38 PM
yeah... they were the ones that were posted on here from awhile back... yaps the coilovers are to the point were they can't turn no more... I guess yuor the regular guys out there... the drop would be perfect... but fro my slammed lifestyle... it's high... DANG... i don't think I want to post pics... the car looks stock... but I'm just going to leave it like that until saturday.. because friday... hopefully it's not raining... I gotta do a couple runs...
Old Apr 13, 2005 | 12:39 PM
sen_jen's Avatar
Meatshake Enterprise
i believe i mentioned that to you before.
Old Apr 13, 2005 | 12:40 PM
sen_jen's Avatar
you should've have just saved for some SR's instead. since i'm keeping my car, i'm gonna run those instead.
Old Apr 13, 2005 | 04:45 PM
636Racer's Avatar
Yup! Silk-Road's are the way to go.
Old Apr 13, 2005 | 05:07 PM
beangrower's Avatar
how much are the sr's? isn't separate spring pre-load and height adjustment? will it go lower?
Old Apr 13, 2005 | 05:39 PM
636Racer's Avatar
Yes, their preload adjustment is separate from the height adjustment. You can also spec your spring rate. I would spec a higher (firmer) spring rate vs the spec'd 350Z which creates more suspension sag. Though the 350Z rates would be ideal for a more plush ride due to the added weight of the G35. MSRP on the coilovers' are $1699.00 n/i shipping.
Give Sean and Clint a ring at 808-848-8794 tell'm Chris with the Twilight G35 referred you. You might get a better deal. Or check'em out at http://www.munkywurks.com/ & http://www.silkroad-usa.com/
MunkyWurks is the main distributor in Hawaii.
And if you search a little harder, Silk Road making exhaust manifolds for the VQ
Crisci33
Jun 29, 2017 08:31 AM
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
Red G Coupe
Video Share
Sep 6, 2015 06:45 PM
