Plenum / idle question
Old Dec 8, 2009 | 11:27 PM
JD_AND_DA_G_RIDE's Avatar
Alright guys, got a question for da DF Dub experts...the polished plenums, throttle body, plenum spacer are installed...got a CEL...figured..ok different air mixture etc...I do the the actual ECU reset/relearn and the idle goes to perfect 750 +/- 100 or so...BUT...as soon as I turn off the car and then turn it back on..the idle runs high again (bout 1k)...and then sooner or later it throws the CEL back on...I'm trying the whole disconnect battery deal but I dont think that's the solution.
I've ALREADY checked the board and the only thing I find are the same instructions on doing the reset...
ideas anyone..anyone???
Old Dec 9, 2009 | 12:43 AM
acidjake75's Avatar
Well you need to pull the code - if you post that we will have a better understanding of where the CEL is coming from. I can pull codes and have a cipher so we could at least look that up and get you pointed in the right direction.
We need that number though - CEL mean sh*t without the code.
BTW Pulling the battery cable doesnt work..Ive left mine off for 3 days ( I do that when I go out of town) and nothing changes except the radio..
Or any autoparts store can pull the code for ya.
Old Dec 9, 2009 | 07:45 AM
waijai's Avatar
i.love.gold
Might need throttle body reset, check ur vacuum hoses, check for leaks.
Old Dec 9, 2009 | 11:44 AM
Thanks for chimin in guys...well the update is...I pulled the battery off overnight and idle is now normal but now my heater was acting up...wdf...I'm guessing whenever we disconnected the plenums maybe air bubbles got trapped in the system...well, I will let everyone know in a few days what happens...thanks homies.
Old Dec 9, 2009 | 01:06 PM
acidjake75's Avatar
nah - you should be good - ECU is just relearning..
Thanks for the update..
Old Dec 9, 2009 | 01:29 PM
g35man04's Avatar
CLUB MODERATOR
yes JD to what Jake is saying...its just re-learning itself...mine did that as well and it was alitlte sluggish but takes a couple of days to re-learn everything..I know we got everything tightened down right so you shouldnt be having a problem.
Old Dec 9, 2009 | 04:09 PM
waijai's Avatar
i.love.gold
Air can leak into the system when you disconnect that coolant hose on the bottom of the throttle body. There's a bleeder valve on the upper left side of the engine bay.
Old Dec 9, 2009 | 04:14 PM
zackt69's Avatar
rarejdm.com
Make sure you didn't accidentally pinch the rubber gasket around the oil cap in between the spacer or plenum during install. It will cause a leak and could trigger the CEL.
Old Dec 9, 2009 | 04:26 PM
g35man04's Avatar
CLUB MODERATOR
Zack I always make sure to check that spot when installing the plenums. That should be okay.
Old Dec 9, 2009 | 04:28 PM
zackt69's Avatar
rarejdm.com
Cool... I've done it myself, just something I always check for now
Old Dec 9, 2009 | 04:49 PM
g35man04's Avatar
CLUB MODERATOR
thats the first thing I checked!!! LOL!
Old Dec 10, 2009 | 10:52 AM
Yeah, Kris is f'n scary....he had all the screws memorized....
Old Dec 10, 2009 | 10:59 AM
g35man04's Avatar
CLUB MODERATOR
lol well the amount of times I have done any of that I have memorized the torque sequence too! LOL along with what every bolt is and where its located
Muski_G
Dec 1, 2023 11:11 AM
Tukeeg35
Engine - Intake/Fuel
Aug 21, 2015 04:19 PM
RA102223
Aug 15, 2015 09:24 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
