Help Headlight one side brighter then other
Old May 13, 2003 | 05:09 AM
G35Performance's Avatar
Hi i just installed new Osram D2R 6000k HID bulbs into my G35 but for some reason one side is brighter then the other. I checked if the bulb by switching the 2 bulbs but it is still on the same side. Does anyone have any clue what is wrong?
Old May 13, 2003 | 07:49 AM
KongzGx's Avatar
Re: Help Headlight one side brighter then other
your headlamps probably need to be leveled.. since the angle of the lights makes a big difference with HID's, esp. brighter ones, they're probably more noticeable than your stock bulbs.
'03 G35 Sedan: ivory/aero body/sport/sunroof
Warning: Objects in mirror are FASTER than they appear
Old May 14, 2003 | 02:44 AM
aikon012's Avatar
your headlight pattern is suppose to be off a little bit to divert it from oncoming traffic. The level of the drivers side should be lower. So if you really do need to level your lights be sure to notice the level of stock lights. Don't level them out perfectly even. They weren't designed staggered without reason.
Old May 14, 2003 | 04:58 AM
Thanks i will try that.
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
wonderizm
Sep 24, 2015 03:09 AM
Mick_L
Aug 25, 2015 04:27 PM
neight
Aug 2, 2015 03:01 PM
attarday
Jul 15, 2015 04:03 PM
