trouble with Fog Lamps
Old May 14, 2003 | 09:19 PM
YngPhllyKd's Avatar
I recently just changed my regular fog bulbs to blue/white ones to match the HID headlights. They look really good, but the highbeams suck REALLY bad! Did anyone experience this problem and does anyone recomend a type of bulb that i should buy? (mine is PIAA xtreme white plasma)
Khal
Old May 14, 2003 | 09:57 PM
Gordgee's Avatar
Administrator
Re: trouble with Fog Lamps
I'm really happy with the Sylvania SilverStar bulbs. The highs are MUCH brighter than stock and the main reason that I changed the bulbs. I don't use the foglights much anyway, and if I did, I'd go with a 'yellowish' bulb.
<font color=green>GG</font color=green>
Old May 15, 2003 | 12:50 AM
rstark's Avatar
So does that mean the SilverStar's are yellowish?
-Rick
Old May 15, 2003 | 09:28 AM
Merlin's Avatar
Staff ALUMNI
Nope, they are actually white and rated at 4000K.
Old May 15, 2003 | 09:32 AM
VNT's Avatar
VNT
There is no Xtreme White Plasma bulb...
I take it you used Super Xtremes or Super Plasma.
PIAA, for the H4's, the high beam filament is lighter than the low beam (or fog) filament. The reason they sacrifaced some color is for improved performance (less light is filtered) over the longer distances high beams are designed for.
Old May 15, 2003 | 02:16 PM
YngPhllyKd's Avatar
thanks for all your help. So, do you think i should get the silverstar sylvania's? How much do they cost? Thanks again for the help
Khal
Old May 15, 2003 | 02:50 PM
VNT's Avatar
VNT
I think Silverstars cost about $25 each. And I think there is still a rebate going on...
http://www.sylvania.com/auto/silverstar.htm
Old May 16, 2003 | 12:14 PM
jmaloneydo's Avatar
What is the model number on those replacement bulbs, on the website look up it only lists infiniti up to 2002, and no G35. So what is the bulb that I wan to buy, if anyone knows please reply.
Once you own the best, everything else is just the rest...
Old May 16, 2003 | 01:27 PM
Gordgee's Avatar
Administrator
The SilverStars are the 9003ST. From any manufacturer, they are listed as the 9003 or H-4 for the fog/high beam.
Old May 19, 2003 | 03:45 PM
jmaloneydo's Avatar
Thanks for the info, so would you recommend the 9003st only or go for the full fog/hi beam combo. What do you guys/gals think?
Old May 19, 2003 | 06:08 PM
Gordgee's Avatar
Administrator
The 9003ST IS the fog/high beam bulb.[img]/w3timages/icons/smile.gif[/img] It's dual filament and the reflectors for each filament change the pattern.
Old May 20, 2003 | 10:51 AM
jmaloneydo's Avatar
Sweet! Thanks for the reply, I am ordering them as we speak. Doesn't this forum rock? You ask a question and bam! you get the answer, long live the G!
Danielek
Aug 18, 2025 01:33 AM
quikrotary
2nd Gen (V36) Sedan
11
Nov 19, 2015 05:14 PM
dseet
Oct 11, 2015 12:40 AM
twentyeggs
Sep 11, 2015 03:58 PM
