Header install: Do I need new gaskets or hardware?
Old Jun 19, 2006 | 02:22 AM
dTor's Avatar
Question Header install: Do I need new gaskets or hardware?
I've got a used set of headers on the way that I bought from a member here. It does not have any gaskets or mounting hardware included. I've been searching for about an hour and cannot find out if I need to use new gaskets and hardware or if the stock stuff can be used.
If I need new gaskets or hardware, where is a good place to order them? Are there any good aftermarket items recommended? BTW, the headers are Topspeed Pro 1.
Old Jun 19, 2006 | 02:38 AM
G352NV's Avatar
Never enough
Its a good idea to get new ones. But you can get away with using the old ones a couple times.
Old Jun 19, 2006 | 02:44 AM
99atlantic's Avatar
i would use new gaskets; you don't want to go through allt hat work only to find out you should've got new gaskets, heh.
Old Jun 19, 2006 | 03:21 AM
dTor's Avatar
I guess new stock gaskets are fine, correct? Nissan dealer, I hope, will have them in stock.
What about the hardware? Factory original, or are there any aftermarket companies (e.g. ARP) that have header studs for us?
Old Jun 19, 2006 | 03:26 AM
G352NV's Avatar
Never enough
The oem studs are fine. The gaskets are up to you. Ive installed three sets on headers on my car with the same gaskets. But if you do change em Nissans are what you want.
G352NV's Avatar
Never enough
Old Jun 19, 2006 | 03:35 AM
dTor's Avatar
Cool. That's what I needed to know. Thanks! X 2
Old Jun 19, 2006 | 04:04 AM
PhxBlue's Avatar
Polyester Pileup FTW!
And there you have it!
tkuntz
20 Inch
21
Sep 26, 2016 09:13 AM
magnetism80
Jan 27, 2016 12:57 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
BradMD_96
Oct 6, 2015 09:31 AM
Albanian122
Engine - Exhaust
Sep 5, 2015 11:23 AM
