DIY for popcharger?
Old Jul 7, 2006 | 11:46 PM
kenempireex's Avatar
DIY for popcharger?
i can't seem to find the DIY for popcharger. I want to look at it, because one of the plastic sheild doesn't seem right. is the upper rubber trim flip inside the filter or outside? It seems like it's suppose to flip outside. Pleas help, thank you.
Old Jul 8, 2006 | 12:28 AM
Kyosho's Avatar
not sure exactly what you mean, but it should be on the outside. otherwise it'd be restricting air flow.
Old Jul 8, 2006 | 12:31 AM
GLuXuRy's Avatar
hope this helps ... just click intsall insrtuctions on the bottom right
http://www.jimwolftechnology.com/cus...asp?PartID=444
Old Jul 8, 2006 | 01:41 AM
what's the best way to solve that AC line problem? where can i find a rubber pad for tube?
Old Jul 8, 2006 | 01:43 AM
GLuXuRy's Avatar
foam and a zip tie... or rubber tubing and a zip tie
auto parts store or home depot
Old Jul 9, 2006 | 12:07 AM
i installed my popcharger, but whenever i step down on the gas, i can hear 'weeeeeeee' the suction sound. Is it normal?
Old Jul 9, 2006 | 01:30 AM
speeddreamz's Avatar
other solution is stillen Ztube, it clears.
Old Jul 9, 2006 | 01:35 AM
akachi's Avatar
here is a link with pics of step by step... good luck
http://www.imagestation.com/album/pi...87496321&idx=1
Old Aug 13, 2006 | 03:04 PM
v3n0m's Avatar
I know this post is a bit old, but just out of curiosity, does anyone know if the popcharger install is bolt on? I saw instructions for a 350 popcharger install and it mentions drilling holes? Is the G35 install different? Do you need to drill any holes? Or is it really simple?
Old Aug 13, 2006 | 03:20 PM
GLuXuRy's Avatar
PC is bolt on... no drilling of any holes is needed... its easy if you have the right tools... which i believe is a 10mm with a extensions, phillips screw driver and umm some patience?
Old Aug 15, 2006 | 05:13 PM
extreme4377's Avatar
Lexus IS350
Ya, installation is a breeze. The only part thats a pain in the *** is dealing with the rubber flaps for the heatshield.
As for the suction sound, thats normal, it whistles until you get on it, then it just roars
Old Sep 1, 2006 | 07:54 PM
066MT's Avatar
You need a flat head too. Just got done installing mine.
Old Sep 2, 2006 | 12:40 AM
TURBOTOM's Avatar
a.k.a kleicoupe
its easy if you take your time and dont rush.
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
Jon81035
Sep 16, 2015 04:58 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
